- Mar 15, 2002
- 2
- 0
- 0
STOP Before you buy a new Volcano 7 you should read this. I purchased a new Soyo MB and a new Volcano 7 cpu fan. The Soyo Mb has a afety feature that shuts down the power supply if it senses no cpu fan connected to the fan header. In connecting the Volcano both ways: 1. as requested by Volcano instructions, the sensor wire to the MB cpu header, and the 2 power wires directly to the power supply, and 2. the sensor wire and the 2 power wires all connected to the MB cpu fan header. IT DOES NOT MATTER, no matter which way you do it, the MB shuts down. DO NOT BUY A OLCANO 7 IF YOUR MB HAS THIS SAFETY FEATURE. The stock cpu fan worked fine. When I contacted Thermaltake (Volcano), with my Soyo MB number and my problem, their sorry support responded by naming a MB entirely different than the one I identified to them and said it was because of the MB. They suggested turning off the safety feature and trying the fan again. That makes a lot of sense, that way if their fan fails I'll be sure to MELT my cpu. Way to go Thermaltake! What do ya say we all buy Cooler Master cpu fans?
