Please not description below is for an office in the UK.
At present in the office we have about 20 Linksys SPA921/941 phones on a hosted PBX. The phones connect to a Cisco Catalyst 2960 48 port switch.
At present the switch carries voice traffic only. The switch did have 2 port base VLANs setup so that the phones were equally spilt across 2 DSL routers. The split was done as 20 phones on G711 is to much for the uplink. all phones active would be about 1.7 Mbs uplink. It was also spilt so we could test DSL connections from different providers. What this did mean was that we had to re-patch cables to the switch when someone moved.
The 2 VLANS connect to different subnets, one 192.168.x.x and one with 30 public IP address on it. The default VLAN is used to connect to the switch for management, and connects to another 192.168.x.x subnet
To resolve the re-patching problems I have changed some of the ports from access mode to trunk mode, and made that port a member of both VLANs. The VLAN tagging is 802.1q. The phones have been set to use the VLAN ID, and the ID on the phone set to the appropriate VLAN ID.
I have not used the cisco voice VLAN feature, mainly as I do not fully understand it, and that appears to only use 1 VLAN ID. I need at least 2, and will be adding 2 more in the near future, as we have 2 other DSL circuits to test.
This appears to be working fine.
What I would like to know is are there any settings regarding the ports I should set.
I would also like to know what the switch will do if a device not setup for VLANs (like an IP Phone with the VLAN ID set to off or a Win 7 laptop/Desktop) is connected to one of the trunk ports?
From what I have seen with the VLAN ID set to off on the phone it still connects, and gets frames from the VLAN with the highest ID.
What I would like ideally is that when the trunk port is connected to a non trunk port that it gets connected to the default VLAN on the switch. That way the phone could reach the management network. DHCP and tftp could then set the config of the phone, including setting the VLAN ID up.
Rob.
Rob.
