Voice dialog too low, everything else too loud...
thestrangebrew1
4,070
763
I picked up a Yamaha Rx-a760 and a klipsch 10" reference sub. I have 5 additional speakers (Energy Take mini series). Hooked everything up last night, including my htpc, with cable and htpc running through the receiver, and the receiver outputting to my tv. Decided to try a movie to see how things sound, and voices are too low, while explosions etc are too loud. I'm constantly adjusting the volume. Any thoughts or remedies I can try to fix this?
Edit: Found a few solutions to try out. Mod can delete...
olds
50,124
779
Does it have Audyssey?
Change Sound Mode.
Turn up center channel
thestrangebrew1
4,070
763
Change Sound Mode.
I think it does. Im not home but found that turning up the center channel should help or fix the issue. Thanks. Will try when I get home tonight.
Sent from my iPad using Tapatalk
JeffMD
2,026
19
Who is doing the audio decode? Is the PC decoding it (every channel is sent to the receiver individually) or is it being bitstreamed to the receiver?
thestrangebrew1
4,070
763
Is there a way to determine this? I just have 1 hdmi from htpc to receiver. FWIW I raised the center channel level and it sounds much more balanced.
Sent from my SAMSUNG-SM-G925A using Tapatalk
JeffMD
2,026
19
Your receiver should let you know if its receiving a PCM stream, or it will show the codec name in the window.
