Er - I think this might need to be moved to the Technical Support forum...
I just discovered that my sweet Raptor loses data that is placed on the D partition. I installed Nero to the D drive, used it once (and browsed the install folder) and then shortly after, noticed the desktop icon was that "broken" icon you get when the file it points to is gone. I looked at the Nero folder and sure enough, most of the install was gone! :0
This was in the span of a half hour, so I know exactly what was going on.
At "approximately" the same time (within minutes) I see the following logged in the event log:
An error was detected on device \Device\Harddisk0\D during a paging operation.
I strongly suspect that anyone experiencing the issue could actually be losing data due to this problem. Some may says thats obvious because of the message, but I had finished an entire install of Nero (50+ MB) and it disappeared minutes later. Thats much bigger than any disk cache, right?
I have a VNF4 Ultra, bios v2 - selected "optimized settings", Raptor 74GB wd740gd, 1GB PQI memory, FX-53 cpu, XP Pro w/sp2 and patches, latest NVidia SW IDE driver (and all other NVidia mobo drivers), NO RAID.
Any ideas? Is there a way to uninstall the NVidia IDE SW driver and replace it with the Microsoft driver without causing a bluescreen? (I've had this happen once by simply uninstalling the NVidia driver)
What about the disk drive properties? Is there a known issue with XP, NForce4, SATA, Raptors and write caching? its currently enabled on the drive.
And no, rebuilding my XP system is not really a valid troubleshooting step. I might have to, but if I can switch from the Microsoft driver to the NVidia driver, I should be able to undo it.
