vnf4 ultra onboard lan not working
jae
1,034
www.facebook.com
my onboard lan isnt working anymore. ill surf the net for 2-3 minutes then the internet will stop working and ill get a BSOD. i tried uninstalling/reinstalling Ethernet drivers sometimes ill get a bsod when setup starts but if it did go thru setup as u know it didnt help.
STOP:0x0000007E or STOP:0x0000000C5
cant remember which one it was because i was having lots of problems last night and jus wrote down bsods i was getting.
GadgetBuilder
148
This is one of the more common symptoms of a problem with the nVidia driver set, particularly if you installed the nVidia firewall. Visit the nVidia mobo forum for more info, although it may take a while to poke through all the complaints to find those matching yours:
http://forums.nvidia.com/index.php?s=f3...ead353326152f9b12af806c46&showforum=34
Sometimes (unpredictably) replacing the nVidia drivers in the normal way leads to BSODs, especially with earlier releases like 6.39 (and often 6.53). The installer is improving with each release so try the 7.13 Intel release on your VNF4 -- I'm running 7.12 Intel Beta on my VNF4 (normal install, 6.53 required a clean install) and it works but has the same "issues" that occurred with 6.53 on my machine. The random nature of the problems with the drivers is peculiar in that when a system has difficulty it generally has difficulty with all releases although occasionally installing a new release will fix things (so I keep trying the new releases).
If you still have problems after a normal install of 7.13, you may have to do a clean install of XP followed immediately by the nVidia drivers (6.53 or 7.13). Installation of the nVidia drivers remains a crapshoot, where a clean install has the best chance of success. There is a good description of the procedure by an owner who has done it successfully:
http://forums.nvidia.com/index.php?showtopic=5146
The most common nVidia driver problems seem to concern NAM -- if you leave it out your probability of success will improve; the 6.53 and 7.1* releases make this easy. Also, consider not including the nVidia IDE driver simply because of the number of owners who seem to think it causes problems; the default XP drivers seem to work fine.
jae
1,034
www.facebook.com
never installed the firewall software. i went about the some way i did when i first built this computer, used the cd the board came with. after installing other drivers and couple restarts i tried to goto the nvidia site download the newest drivers but it frozed the download and soon got the BSOD. tried again after restart and cycle of the modem same problem. so i took out ethernet pci card out of the old pc and have been using it since. i dont think im even gonna try to fix the onboard lan i dont want to run into more problems :-\
