- May 14, 2004
- 19
- 0
- 0
Okay. Here's my newest dilemma.
I read about temperature reporting issues on the Chaintech VNF3-250, so I downloaded the latest BIOS to correct it. Prior to the flash, the CPU temp was an astoundingly incorrect 8 degrees Celsius. Afterward, it is reading a more reasonable 40 degrees Celsius. The system temp is 37. I think an additional 120mm fan in the back of the case would only help, but overall that's not too terrible.
Now, I want to get this information in Windows and not just in my BIOS settings, so I downloaded SpeedFan to act as a monitor. Here's what it tells me:
Temp1: 40C
Temp2: 37C
HD0: 36C
Temp3: 127C :Q
What?!? Something in my case is clocking in at 270 degrees Fahrenheit? That can't be.
So tell me. Is there a mystery hotspot that I might be missing or is SpeedFan reading from a sensor gone bad or is Speedfan just ... well ... cracked out?!?
Temp1: 40C
Temp2: 37C
HD0: 36C
Temp3: 127C :Q
