VMware Workstation Pro and VMware Fusion Pro now free for personal use
Steltek
3,421
1,159
Broadcom has announced that Workstation Player and Fusion Player are now discontinued products. VMware Workstation Pro 17 and Fusion 13 Pro are being released as free for personal use to replace them:
https://blogs.vmware.com/workstatio...-pro-now-available-free-for-personal-use.html
Now, obviously "free" is relative and TANSTAAFL applies (and especially with Broadcom, considering how they are such a pain to deal with and that you can't trust anything they tell you) so you'll probably be datamined out your rear orifice.
That said, to download you have to register in their support portal at the link in the blog. You do not have to complete a profile if it asks you to, just skip it for later. You have to be logged in to the support site, then click on the download links in the blog above. The first time you download, it will probably force you to complete a certification that you are a US resident and that you won't export the product out of the US before it will allow you to download (at least, it did for me anyway).
You can also find direct downloads for VMware stuff at the following link (you have to be logged in at the Broadcom support portal for it to work though):
https://support.broadcom.com/group/ecx/downloads
Jimminy
502
187
Who would want this when they could download virtualbox without all the hassles?
Steltek
3,421
1,159
Both have their problems. I simply prefer Workstation at this time for simple virtualization stuff.
19,203
What does VMware have and other virtualizers don't that makes it a security risk to export?
manly
13,458
4,168
VirtualBox is an Oracle product. Friends don't let friends use Oracle stuff. :p Meanwhile Broadcom aspires to be just like Oracle. :tearsofjoy:
I still have a soft spot for VMware, having used them since the original desktop 1.0 for Linux release.
Thankfully KVM is rock solid; and I've thought about playing around with Proxmox VE and GPU passthrough.
  • Love
Reactions: Steltek
Steltek
3,421
1,159
Honestly, have no clue beyond the fact that Workstation has always been a closed source commercial product. It was also subject to export restrictions long before Broadcom bought VMware.
Oracle's branded commercial version of Virtualbox is also on the export restriction list as well. It may be that Virtualbox being open source (it has been, since 2007) in some way exempts it from export controls.
manly
13,458
4,168
Performancewise? Done any benchmarks against VMware/Virtualbox/Hyper-V?
I let the pros do benchmarks. Did a bit of searching earlier, and KVM is some "tens of thousands" of LOC while VMware (in totality) is many millions. Some sources (maybe biased) say that KVM is one of the best performing hypervisors, but VMware is no slouch and seems to scale a little higher. KVM is heavily used by some of the largest cloud providers, including GCE and AWS (historically they used Xen for compute).
Proxmox VE uses KVM for virtualization and this person says it beats ESXi in storage throughput:
syadnom
152
friends don't let friends use diabolical corporate software and broadcom just converted vmware into that.
Xen and KVM are both faster than vmware. Vmware has been more about integrations and management, fitting better into corporate IT infrastructure. If you don't need tight integration like that, then vmware is the inferior product and has been for nearly a decade.
proxmox ve, which is KVM based, is fantastic for small setups. Single servers or small clusters. top-tier performance, good management, a fantastic CEPH cluster management for hyper-converged setups.
virt manager or any number of suites on KVM exist on your favorite linux flavor.
XCP-ng also fantastic but based on Xen. It's XenServer for those that think Citrix is evil. I find that it's configuration and management is a lot more convoluted especially if you need to recover a virtual machine but to each their own.
Ajay
16,094
8,114
Hmm, need to change my vmware login to broadcom. I was sent a link a while back - duh. Glad I didn't pay for the upgrade to VMW 17.
