- Jul 15, 2002
- 16
- 0
- 0
Hello,
I have this problem with my computer that when I try to start it in safe mode or normal mode I keep receiveing the message: "VMM32.VXD is required to run Windows. If this file is not in your PATH, you may need to reinstall Windows." Now I went to the Microsoft support center for a solution and I found this:
Method 1
At the command prompt, type:
dir vmm32.vxd /s
If the Vmm32.vxd file is not found, you must install Windows 95 or Windows 98 again. If the Vmm32.vxd file is found, note the folder in which it is located, and then continue with step 2.
At the command prompt, type the following commands, pressing ENTER after each command
cd windows
ren folder system
where folder is the folder you noted in step 1.
Restart your computer.
Method 2
Using a text editor (such as Notepad), edit the Autoexec.bat file and add or modify the PATH line so that it includes the Windows\System folder. For example, add the following line to your Autoexec.bat file:
path=c:\windows\system
I tried method 1 and I receive the message "duplicate file in use" Method 2 didn't work either.
My question is am I doing something wrong or missing a step? I know the vmm32.vxd file is in the computer (the location is "c:\windows\dir00005\" by the way).
Please Help.
Thanks in advance.
Method 1
dir vmm32.vxd /s
cd windows
ren folder system
Method 2
Please Help.
Thanks in advance.
