VIZIO 42" LCD 1080p 60Hz HDTV, E421VO: $198 at walmart
Status
Not open for further replies.
Pardus
http://www.walmart.com/ip/15992341?w...14192592639724
The VIZIO E421VO HDTV is a 42-inch LCD TV that delivers full-HD picture. Equipped with a 100,000:1 contrast ratio, the clear picture HDTV resolves the brightest white, darkest black and all the shades in between with excellent accuracy. With 178 degree vertical and horizontal wide viewing angles, you can view a clear picture from anywhere in the room. It features a refresh rate of 60Hz that reproduces live action like sports broadcasts in stunning detail. The Vizio 42" class LCD 1080p 60Hz HDTV also boasts of ambient light-sensing technology that synchronizes the backlight according to the room's brightness. This allows for a fatigue free viewing experience even during long sessions. The LCD HDTV can effortlessly render videos up to full HD 1920 X 1080 resolution. It comes with a robust 5 ms response time which facilitates robust console gaming. Overall, if you are looking for a sleek TV that delivers crystal-clear picture quality, the E421VO is a smart choice.
VIZIO E421VO HDTV:
16:9 LCD panel
With 1920 x 1080 full-HD resolution
Wide 178-degree vertical and 178-degree horizontal angles
See a clear picture from anywhere in the room on the VIZIO 42" 1080p LCD HDTV
Built-in ATSC digital/NTSC analog tuner
Receive digital broadcasts including HDTV programs, where available
High brightness of 500 cd/m2
Place your TV anywhere
100,000:1 dynamic contrast ratio and with 8-ms. response
Ensures bright whites, rich blacks, vivid colors and less blurring during on-screen motion
Also available:
$298.00: Vizio 47" LCD 1080p 60Hz HDTV,E471VLE
http://www.walmart.com/ip/Vizio-47-C...71VLE/20461478
$228.00: SANYO 46" LCD 1080p 60Hz HDTV,DP46841
http://www.walmart.com/ip/SANYO-46-C...46841/16401800
Says in stock at my location but once I go to cart its claiming its out of stock.. what a load of bs.
OK, I tried this with my local store and it says it is out of stock. Then I search for the next nearest store approx 25 miles and it says it is available. I placed an item in the cart and then it says it is out of stock! So I tried another nearby store approx 35 miles and this time the order went through. So there's only one obstacle left before total success and that is when I pick it up tomorrow! Wish me luck!
Follow up on the above placed order, it was cancelled. So did anybody got lucky with this pricing error?
Status
