Visual FoxPro drive index
Status
Not open for further replies.
ShayLacy
Stopped working the drive index. What is the procedure ? If it is easy...
Backup - no. Try without a backup.
It would seem not difficult - the index information is recoverable, but something goes wrong.
ALTER DATABASE DATAFILE 'g:\ORACLE\ORADATA\SKONTCO\INDX01.DBF' offline DROP;
and so with all the index files.
Then a vicious circle about primary indexes.
DROP TABLESPACE INDX swears on primary indexes.
Disable constrain primary indexes also impossible... What is the correct order of action?
Thread locked by OP's request -- Programming Moderator Ken g6
The order is:
It is necessary to disconnect tablespace (but not the file as you did)
ALTER TABLESPACE "INDX" OFFLINE;
To mark all indexes in this tablespace as unusable and to reconstruct.
For example:
BEGIN
FOR c_rec IN (SELECT a.index_name
FROM SYS.all_indexes a
WHERE a.owner = 'SUPERMAG' AND a.tablespace_name = 'INDX')
LOOP
BEGIN
EXECUTE IMMEDIATE 'ALTER INDEX ' || t_rec.table_name || ' UNUSABLE';
EXECUTE IMMEDIATE 'ALTER INDEX ' || t_rec.table_name || ' REBUILD TABLESPACE NEW_INDX';
END;
END LOOP;
END;
And then to remove old tablespace.
You can still try to make export and import. While gives the chance - do export.
If nothing helps, you can download foxpro dbf recovery software for .dbf file
Specific software recommendation removed, as spammers often do this. -- Programming Moderator Ken g6
Status
