- Feb 19, 2011
- 5
- 0
- 0
I am having a problem with my code :\ and would appreciate any help.
[/COLOR][/SIZE][/COLOR][/SIZE]
The code is suppose to add a year and go to the next term until it reaches 120 hours. This is all done with a for loop and added to a label.
In the code the user will enter their starting term and year, and starting credit hours in 3 textboxes(fall, spring, and summer). In the second line the user will enter the number of credit hours they plan to take in each of their remaining fall, spring and summer terms. the user than click btnTograd and it will compute and display a term by term plan for each term from starting term until the student attains the total credit hours needed to graduate (120). The last term will show only the number of hours needed to get to 120.
Thanks in advance for your help.
Code:
[SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Option[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Strict[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]On
Option[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Explicit[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]On
Public[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Class[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] gradplan
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Const[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] fullTimeTuition [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Decimal[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] = 2485
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Const[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] partTimeTuition [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Decimal[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] = 207
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Const[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] inflationRate [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Double[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] = 0.02
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Const[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] totHoursForGrad [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Integer[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] = 120[/SIZE]
[SIZE=2]
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] btnToGrad_Click([/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] sender [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] System.Object, [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] e [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] System.EventArgs) [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Handles[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] btnToGrad.Click[/SIZE]
[SIZE=2]
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] currentYear [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Integer
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] currentTerm [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]String
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] totalHours [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Integer
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] hours [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Integer
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Dim[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] tuition [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Decimal[/COLOR][/SIZE][/COLOR][/SIZE]
[/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]'Print the headings in the labels
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]lblGradInfo.Text = [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]" Term"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] & [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]" Hours"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] & [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]" Tuition"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] _
& [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]" Tot Hrs"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] & ControlChars.NewLine[/SIZE]
[SIZE=2]
[/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]'execute the loop until it reaches 120 hours
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]For[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] counter = 1 [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]To[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] totHoursForGrad
[/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]'Determine the hours
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Select[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Case[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] txtStartTerm.Text
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Case[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Is[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] = [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"F"
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]hours = [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]CInt[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2](txtFallHours.Text)
totalHours = [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]CInt[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2](txtStartHours.Text)
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Case[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Is[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] = [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"S"
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]hours = [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]CInt[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2](txtSpringHours.Text)
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Case[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Is[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] = [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"U"
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]hours = [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]CInt[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2](txtSummerHours.Text)
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Case[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Else
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]MessageBox.Show([/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"Enter a valid Start Term (F/S/U)"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2])
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]End[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Select[/COLOR][/SIZE][/COLOR][/SIZE]
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]currentTerm = txtStartTerm.Text
[/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]'calcualte tuition
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]If[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] currentTerm = [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"F"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Or[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] currentTerm = [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]"S"[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Then
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]If[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] hours >= 12 [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Then[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]' start of nested if
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]tuition = fullTimeTuition
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]End[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]If[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]' end of nested if
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]tuition = hours * partTimeTuition
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]'Add term hours to total hours
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]totalHours += hours
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]If[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] currentYear > 1 [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Then
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]txtStartYear.Text = [/SIZE][SIZE=2][COLOR=#a31515][SIZE=2][COLOR=#a31515]""
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2][/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]End[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]If[/COLOR][/SIZE][/COLOR][/SIZE]
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]currentYear += 1
[/SIZE][SIZE=2][COLOR=#008000][SIZE=2][COLOR=#008000]'Print Label
[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2]lblGradInfo.Text += currentTerm & currentYear.ToString.PadLeft(2) & _
hours.ToString.PadLeft(15) & FormatCurrency(tuition).ToString.PadLeft(17) _
& totalHours.ToString.PadLeft(10) & ControlChars.NewLine
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Next[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] counter[/SIZE]
[SIZE=2]
[/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]End[/COLOR][/SIZE][/COLOR][/SIZE][SIZE=2] [/SIZE][SIZE=2][COLOR=#0000ff][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/COLOR][/SIZE]
