- Jul 5, 2004
- 434
- 0
- 0
Anyone know if it is possible to prevent windows from shuting off a wireless connection when changing users, and/or having it up at the login screen?
It seems that everytime I try to remote into my laptop running vista(5308) it logs out locally causing the wireless connection to shut off before the remote session can take over. In XP I have it setup so that it will connect at login.
It is a secured network with WPA-PSK(AES), but I believe that it would do it even if it was unsecured as well. I am currently using windows built in utility, but it is a intel card, so if the proset utility works I could try that.
*Wonders if this belongs in OS forum
Intel proset utility isn't compatible with Vista yet
