Vista Startup problems
Jedi940
42
I have been disabling some services trying to get my startup and hibernation times shorter but the only thing I seemed to have done is make my startup longer. I just created a bootlog file and there are tons of drivers that didn't load. It seems that the system keeps trying to load the drivers and failing. What can I do to fix this???
Here is the boot log:
Microsoft (R) Windows (R) Version 6.0 (Build 6000)
12 25 2007 20:06:49.375
Loaded driver \SystemRoot\system32\ntoskrnl.exe
Loaded driver \SystemRoot\system32\hal.dll
Loaded driver \SystemRoot\system32\kdcom.dll
Loaded driver \SystemRoot\system32\PSHED.dll
Loaded driver \SystemRoot\system32\CLFS.SYS
Loaded driver \SystemRoot\system32\CI.dll
Loaded driver \SystemRoot\system32\drivers\Wdf01000.sys
Loaded driver \SystemRoot\system32\drivers\WDFLDR.SYS
Loaded driver \SystemRoot\system32\drivers\acpi.sys
Loaded driver \SystemRoot\system32\drivers\WMILIB.SYS
Loaded driver \SystemRoot\system32\drivers\msisadrv.sys
Loaded driver \SystemRoot\system32\drivers\pci.sys
Loaded driver \SystemRoot\system32\drivers\volmgr.sys
Loaded driver \SystemRoot\system32\DRIVERS\compbatt.sys
Loaded driver \SystemRoot\system32\DRIVERS\BATTC.SYS
Loaded driver \SystemRoot\System32\drivers\mountmgr.sys
Loaded driver \SystemRoot\system32\drivers\pciide.sys
Loaded driver \SystemRoot\system32\drivers\PCIIDEX.SYS
Loaded driver \SystemRoot\System32\drivers\volmgrx.sys
Loaded driver \SystemRoot\system32\drivers\atapi.sys
Loaded driver \SystemRoot\system32\drivers\ataport.SYS
Loaded driver \SystemRoot\system32\drivers\fltmgr.sys
Loaded driver \SystemRoot\system32\drivers\fileinfo.sys
Loaded driver \SystemRoot\System32\Drivers\PxHlpa64.sys
Loaded driver \SystemRoot\system32\drivers\ndis.sys
Loaded driver \SystemRoot\system32\drivers\msrpc.sys
Loaded driver \SystemRoot\system32\drivers\NETIO.SYS
Loaded driver \SystemRoot\System32\Drivers\Ntfs.sys
Loaded driver \SystemRoot\System32\Drivers\ksecdd.sys
Loaded driver \SystemRoot\system32\drivers\volsnap.sys
Loaded driver \SystemRoot\System32\Drivers\spldr.sys
Loaded driver \SystemRoot\System32\drivers\partmgr.sys
Loaded driver \SystemRoot\System32\Drivers\mup.sys
Loaded driver \SystemRoot\System32\drivers\ecache.sys
Loaded driver \SystemRoot\System32\DRIVERS\fvevol.sys
Loaded driver \SystemRoot\system32\drivers\disk.sys
Loaded driver \SystemRoot\system32\drivers\CLASSPNP.SYS
Loaded driver \SystemRoot\system32\drivers\crcdisk.sys
Did not load driver @nettun.inf,%6to4mp.displayname%;Microsoft 6to4 Adapter
Did not load driver @nettun.inf,%isatap.displayname%;Microsoft ISATAP Adapter
Did not load driver @nettun.inf,%tunmp.displayname%;Microsoft Tun Miniport Adapter
Did not load driver @hal.inf,%acpi_amd64.devicedesc%;ACPI x64-based PC
Did not load driver @netrasa.inf,%mp-l2tp-dispname%;WAN Miniport (L2TP)
Did not load driver @netrasa.inf,%mp-ip-dispname%;WAN Miniport (IP)
Did not load driver @netrasa.inf,%mp-ipv6-dispname%;WAN Miniport (IPv6)
Did not load driver @netrasa.inf,%mp-pppoe-dispname%;WAN Miniport (PPPOE)
Did not load driver @netrasa.inf,%mp-pptp-dispname%;WAN Miniport (PPTP)
Did not load driver @cpu.inf,%amdk8.devicedesc%;AMD K8 Processor
Did not load driver @battery.inf,%acpi\acpi0003.devicedesc%;Microsoft AC Adapter
Did not load driver @battery.inf,%acpi\pnp0c0a.devicedesc%;Microsoft ACPI-Compliant Control Method Battery
Did not load driver @oem16.inf,%nvenetfd.devicedesc%;NVIDIA nForce Networking Controller
Did not load driver @display.inf,%stdvga%;Standard VGA Graphics Adapter
Did not load driver @sdbus.inf,%pci\cc_080500.devicedesc%;SDA Standard Compliant SD Host Controller
Did not load driver @oem31.inf,%bcm430g_devicedesc%;Broadcom 802.11b/g WLAN
Loaded driver \SystemRoot\system32\DRIVERS\cpqbttn64.sys
Loaded driver \SystemRoot\system32\DRIVERS\wmiacpi.sys
Loaded driver \SystemRoot\system32\DRIVERS\nvsmu.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbohci.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbehci.sys
Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys
Loaded driver \SystemRoot\system32\DRIVERS\HDAudBus.sys
Loaded driver \SystemRoot\system32\DRIVERS\ohci1394.sys
Loaded driver \SystemRoot\system32\DRIVERS\rimmpx64.sys
Loaded driver \SystemRoot\system32\DRIVERS\rimspx64.sys
Loaded driver \SystemRoot\system32\DRIVERS\rixdpx64.sys
Loaded driver \SystemRoot\system32\DRIVERS\i8042prt.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\SynTP.sys
Loaded driver \SystemRoot\system32\DRIVERS\mouclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\msiscsi.sys
Loaded driver \SystemRoot\system32\DRIVERS\rdpdr.sys
Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys
Loaded driver \SystemRoot\system32\DRIVERS\swenum.sys
Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys
Loaded driver \SystemRoot\system32\DRIVERS\umbus.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdhid.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbhub.sys
Did not load driver @oem30.inf,%hdaudiofunctiondriver.venice5045.devicedesc%;Conexant High Definition Audio
Did not load driver @oem12.inf,%hsfmodem%;HDAUDIO Soft Data Fax Modem with SmartCP
