CrazyTired
First of all, I'm going to go ahead and apologize in advance. I'm *crazy tired* right now and will probably word this all wrong 🙂
Basically.... My friends computer is pretty hosed and we need some help getting it back on the right track. Let's get the specs out of the way: A64 3000+, 1.5GB PC3200 ram, Radon 9550 (128MB) AGP. His mobo is a Gigabyte GA-K8U-939... He has a SATA drive along side 2 IDE drives.
The problem started a couple of weeks ago when he decided to install Vista...Although his XP install was pretty screwed up too since he has a bad habit of downloading viruses/malware ect. The first problem involved actually installing Vista.... From what I understand he partitioned his SATA drive and was going to try to dual boot it with XP. Although apparently every time he tried to do this he would get a BSoD during the installation process.
After that he decided to use one of his IDE drives to install Vista on... He said he got the BSoD doing this as well. Finally he tried to unhook his SATA drive all together and try it again, after which it seemed to install just fine. Problem is, once he hooked his SATA drive back up he couldn't dual boot. If he had it set to boot first, it still wanted to boot off the IDE drive. Since he uses his computer for work he decided to say "screw Vista" and tried to unhook the IDE Vista was installed on.. After that he just gots a message saying something like "Failed to find system disk" (Pretty sure that's not the exact error, but it's something like it) during POST
I believe this has something to do with SATA drivers, unfortunately I don't know much about sata drivers and neither does he. After looking at his mobo website we saw some sata drivers to load during an OS install, and the chipset which included sata drivers as well (So we thought?). I believe he used the chipset drivers and can currently run Vista with the SATA drive plugged in, but still cant' boot from the SATA.
Also, Vista is running VERY, VERY slow on his computer. I'm not entirely sure if it was running this slow without the SATA plugged in, but I don't think so. It's so slow that it's almost unusable, a rig running XP with 128MB of ram and running tons of background apps would run circles around his computer right now 🙂 Strange thing is, the Vista rating system thing still shows his computer at 4.2 or something.... Also, he's been saying that while in Vista he has been getting the BSoD randomly....
Right now he would do anything to just have the ability to launch XP or dual boot without having any problems at all. I was hoping that somebody here could give any thoughts on what could be going on and what he could do to fix this. I realize that I made a mess of my topic and probably made it hard to read, I apologize again 🙂
Thanks for any help 🙂
