Hi, I'm using windows vista ultimate x64 SP1 on a gateway laptop with a Realtek RTL8187S Wireless LAN PCI Adapter. My router is a WRT54GL running 4.30.11 firmware. Vista regularly seems to -forget- the wireless key (or something like that) of the network, I'm downloading something, watching a movie or playing a game, then I alt+tab back to desktop, and notice that Vista is reporting "Local Only" on my wireless connection. I try to disconnect and reconnect, it says the wireless key is wrong, I re-enter the key and it reconnects properly. This only works for WPA though, WPA2 doesn't reconnect and I need to lower the security setting to WPA to make it work. Does anybody know if this is a common problem, or if there is a fix? It is getting really irritating. It happens more when using WPA2 than WPA.
Thanks for -any- help.
Stern
Stern
