Skitzer
Originally posted by: SynthDude2001
Originally posted by: Doggiedog
I'm tempted to install this but can this OS be dual booted or will it overwrite my XP Pro?
Thanks.
Install it to a separate drive/partition and you'll be fine. It will overwrite the boot loader (though you can still boot to XP by choosing "Earlier Version of Windows" at the menu), but if you decide to get rid of Vista later you can always boot to a recovery console for XP and run "fixboot" (or "fixmbr", I always forget which is which 😛) to restore the original XP one.
Actually before you run fixmbr you have to go into XP and remove the files/folders that Vista puts in there otherwise it won't work.
