- Dec 20, 2007
- 431
- 0
- 0
I have 6 GB of RAM installed. System properties says 6.0GB installed, but
actually only 5374 MB ram is available to Windows....
Checked using Start-> type winver in search and press enter.... in the
bottom it shows 5,503,160KB available to windows.
I am using vista ultimate x64, Memory hole remap is enabled in the BIOS.
BIOS shows 6144 MB during post. Memtest 86 also recognizes 6144 MB and tests
all of it.
My board is Maximus formula, CPU - Core 2 Extreme QX9650, 6 GB RAM
installed, 8800GT 512 MB PCI E card.
More info....
under HKLM in registry->hardware->resource map->system resources->physical
memory, I checked the address range of the instaled memory, it is as follows
PHYSICAL ADDRESS
START 0x100000 Length: CFE80000
Start: 0x0000000100000000 Length: 80000000
These are HEX values, open calculator, in scientific mode, select HEX enter
CFE80000 and add 80000000 and then press DEC.... now divide by 1024 twice...
u will get the amount of RAM that is mapped in MB. it shows 5374.5 MB.
DEP is enabled, Memory Remap feature is enabled in BIOS.
I tried manually editing the Registry values for devices, jus adding
FFFFFFFF to the value in Binary, which will make the values 00000001xxxxxxxx
so that Devices are mapped from 8.0 GB and downwards, but when I restarted,
all the settings turned back to original values in registry too. I am not
able to remap the resources using device manager, on the resources TAP even
after enabling PCIPnP OS.
Why this problem in Vista? I am using SP1.
I jus dont want my OS to show 6 GB RAM but use jus 5374 MB as it is
happening now.
What is the problem here? with x64 too? and all my hardware is x64 Compatible.
Got any solutions or even Ideas to try?
all of it.
More info....
PHYSICAL ADDRESS
happening now.
