- Nov 18, 2004
- 945
- 0
- 76
Hello my friends, I am running into troubles with Windows Vista?. I have several MP3s that WMP11 will not play.
Each time I try to load one of them I get an error: "An audio codec is needed to play this file. To determine if this codec is available to download from the Web, click Web Help."
So I click Web Help, which brings me to the error message C00D10D1. And that tells me that I need to search WMPlugins.com, which I do as well.
The search on that site tells me that the codec isn't found, and that I should search on the web for it. Now I have done that, and I have downloaded a lot of different codec packs too. I downloaded and installed AC3Filter, K-Lite Mega Codec, and Vista Codec Pack.
I didn't install them all at the same time either. I uninstalled one before installing the next. But they didn't help me out at all, not for WMP11 at least. I can get the file to play in a different program, but that program doesn't have burning capabilities.
I can also get the file to play by changing the extension from MP3 to MP2. But when I do that, I can't burn the file either. I want to burn it as audio, not data.
So I was wondering if anybody had any ideas on what to do to be able to burn this on Vista Home Basic. Thanks in advance!
edit: I also googled the error code, but I didn't find anything that worked. Vista won't give me the permissions that I need to rename the file for a new download, and when I try to run regsvr32 it comes up with an error. So maybe this will work if I can get higher permissions, but so far, I don't know how to do that. The controls are locked to full access for trusted installers only. Hmmm.
