- Oct 26, 2008
- 4,442
- 1
- 0
I recently began having these issues. Not sure what the problem is.
When browsing files, sometimes explorer.exe will just hang and lock up. Also this happens using the windows Save As dialog - I ran into this issue saving images. It would crash trying to save using the Windows Save As dialog, but if I used the programs own Save As dialog that was different, it works fine.
Tried to install a Visual C++ Redist pack and that locked up and would not go farther.
If I try to run a command prompt as and administrator, nothing happens.
Any program that I try to run as admin doesn't work. I get another consent.exe process in the task manager, but nothing happens.
Also windows updates say there are updates, and when I click download, it just sits there and eventually explorer.exe crashes.
Any ideas? I tried running SFC, but can't run the command console as an admin as required.
