BonzaiDuck
I don't know if the hardware profile is so relevant now: 680i chipset, new BIOS, dual SATA2 in RAID0 (nVidia controller), dual 9600 GT cards in SLI, 4GB (two successively-tried 4GB 2x2GB RAM kits), Wolfdale/Penryn E8400 processor . . . .
AND . . . . . . . VISTA64
First, I got through the "4GB causes BSOD upon installation" problem. The OEM install DVD was pre-SP1, and I used a 2GB RAM kit to update to SP1.
Then, I began stress-testing with PRIME95 (64-bit version). All good and well with the small-FFTs test. Then I ran Blend-Test, and after 20-minutes, like clockwork every time, I'd get a BSOD. I replaced the RAM-kit with a 2GB kit, and no problem. So I RMA'd the 4GB kit.
Meanwhile, I decided to try a different set of 4GB sticks -- different manufacture, reviews showed high reliability.
Guess what?!! "BSOD after 20 minutes, running PRIME95 Blend-Test." Both kits check out fine with MEMTEST86+ over 13-hour test sessions.
But "20 minutes" is probably indicative of an OS-related problem -- the G$*&MN SCREEN-SAVER. I tried to disable it, but "no cigar" -- it keeps activating after 20 minutes. As I indicated, this seems to coincide with the Blend-test BSOD occurrences -- 20 minutes running.
Does anyone have any suggestions while I continue to trouble-shoot this on my own? I have to notify G.SKILL that the RMA was a mistake.
Eat S***, choke and die -- Burn in Hell, Microsoft and VISTA!! [My choice, though. I wanted to find out both angles: How good it was, and how bad it was, and I wanted a 64-bit OS to play with -- ascertaining the same "good . . . bad" in a more general sense.]
I NEED to get THROUGH this . . . . . and it's not the worst "new-OS" problem I've ever had over the time since Windows 3.0 . . . . . but . . . . . P-I-T-A!!!
