Vista 64 and burning dvd problems
Kamui
Hi guys,
I installed Vista 64 a few days ago and I am having some problems burning dvds... I was wondering if you encountered the same problem.
My setup is:
DFI Ultra-D NF4
Amd X2 3800+
2gb OCZ Platinum DDR
1 WDC raptor 150gb
2 WDC 320gb drive in Raid-1
1 DVD burner - pioneer 111d
I used the latest nforce drivers 16.08 and everything seems to be stable. But for some reason, I cant burn my dvds at 16x like I used to.... it is more like 8x. Also, burns will often fail to verify.
Thanks
K.
no idea, i switched to 64-bit vista from 32-bit without any issues.
my specs:
intel 965 chipset
pioneer dvr-212d dvd writer SATA
set to AHCI
Originally posted by: Kamui
Hi guys,
My setup is:
DFI Ultra-D NF4
Amd X2 3800+
1 WDC raptor 150gb
Thanks
K.
What are you using for burning software?..I know both latest Nero 7/8 work fine with Vista x64 as well as Ashampoo Burning Studio 7 .
All I can suggest is you try different DVD brand/discs and update your firmware on your burner,maybe try different software?
thanks for the replies guys,
I used nero 7 and 8 and ashampoo... but they are all giving me problems... maybe it is a drivers problem with the NF4 chipset...
I thought latest was 15.01 drivers at Nvidia's website for chipset drivers for NF4?
I'm using the 15.01s with my NF4 ultra board and have no problems with burning etc..always does a good burn everytime,this is with nero 7 and Vista x64.
nVidia has released nForce drivers 16.08 WHQL for XP and Vista in the 32 and 64-bit varieties. These are intended for the new Intel IGP chipsets, but may work on other boards with some INF modification.
Think I stick with the safe official 15.01s 😉,which are still showing as the latest at their site for NF4.
