Originally posted by: mnikkel55
I'm building a DX10 gaming system with an E6700. Is there any reason why I shouldn't go with the 64bit version of Vista? I seem to recall hearing something about the 32bit version being better for gaming, but I can't remember where I heard it or why.
32bit is more mainstream, so the drivers are a bit more mature. It was a problem on launch for both 32 and 64...its pretty good in 32bit land right now, but I havent tried 64bit myself, although I've heard it ain't too shabby.
Don't bother with 64-bit unless you have, or plan to have 4gb+ ram soon...thats really the key distinguishing feature between the two.
Hmm, i'm kinda suprised to see you recommending 32-bit.
One can argue it all they want, but the simple fact is, 32-bit is a very short term dying future path, simply due to RAM alone.
Drivers aren't really much worse w/ 64-bit than 32-bit, though nVidia is possibly the worst company in existence for drivers for anything, so be warned...
Overall though, the reason not to go 64-bit is if a certain application or driver for a specific device you have doesn't work, which is relatively rare.
In short, do a search...
http://forums.anandtech.com/me...&keyword1=vista+AND+64
I link to a bunch of other threads there...
Well, I'm making a few assumptions:
That he'll have the retail version with both 32bit and 64bit, and he has no problem with reinstalling later.
He has less than 4gb of ram.
The state of drivers is a crucial factor for a gaming system, and although 64bit might not be too bad, I've never heard of 64bit drivers that were in a better state than the corresponding 32bit drivers.
If any of the above arent the case, well then, 64bit all the way. I'll probably make the change in a few months when theres finally a game that can put 4gb of ram to good use. 64bit is the future. It's here and now and all, but you don't really NEED it yet.
While I only have 2gb of ram at the moment 4gb is definitely a possibility within the next year or so. I was also planning on getting the OEM version to save a bit of money.
There really aren't many issues with 64-bit.
I personally held off installing my 64-bit version of Vista for so long, but now that i've used it for a couple months, i honestly don't know why i was waiting.
I'm not even much of a gamer, but here are the games i presently have installed (haven't encounted any that don't run in Vista 64 yet): http://www.imageannex.com/image/7385.jpeg
The full retail version of home premium is $240. The OEM version is $115. Even if I swap out my MoBo and have to buy a second copy, I come out $10 ahead by going with the OEM version.Originally posted by: BD2003
Well, then go with 64bit I suppose, and just deal with any bugs if they come up. I'm not sure how much you save by going with OEM, but I am pretty sure they're tied to your motherboard, and you might end up losing money in the long run by having to repurchase if you ever upgrade too much.
