Visiontek TI4600 wont fit in ECS K75SA
sheltem
Saw this on Hardocp and it got me worried. I preordered a Visiontek TI4400 and was wondering if I would have the same problems. I haven't seen this problem anywhere else but HardOCP. Anyone care to ellaborate. BTW the guy got around the problem by shaving some plastic off his IDE cable.
Same problem with the epox 8HKA+. People are saying it's the board maker's fault, but wouldn't it be easier to change the graphics card since these motherboards have been on the market longer?
The Video card sits directly over the second IDE channel.
HOWEVER the GF4 does fit .
I don't know why anyone would say it wouldn't. You just have to bend the cable itself down towards the motherboard and push it out of the way.
My wife and daughter both have K75SA motherboards.
I got a GF4 1st day, only to find out it was DOA.
I thought maybe it was a conflict on my motherboard so I tried to install it on my wife's.
It fit just fine and she does have the second channel in use.
Unfortunately the card was just bad 🙁
