Visiontek Geforce3 Heatsink removal
flashbacck
1,921
hey all. Has anyone removed their heatsink from the visiontek geforce3? How is it attached? screws? tape? I'm planning to remove it and stink a better heatsink on.
crash2much
220
Just took mine off today. There are 2 spring loaded pins that need to be removed first. There the black ones that are pushed through the sink on the gpu side and go through the board. Pinch them on the bottom side with some needle nose pliers, and they pop right off.
From there, gently pry the sink of the gpu with a screw driver, use something for leverage so ya don't dork up the card( I used a pad of post a notes). The epoxy used wasn't all that tuff, not much force was needed. Thats the long answer
Short answer
Pinned and epoxied
Ps.
I think it's a good idea to lose the stock heatsink on the Visiontek card. I went from running the stock sink at 47C to 38C with a Blue Orb.
Don't throw the old one away, though. Changing the heatsink can void your warrantee, so should something happen, you might want to slap it back on before you rma it.
EdipisReks
2,722
mine had a soft, tape like adhesive instead of epoxy. either way, it shouldn't be hard to remove the heatsink. if you are worried about the adhesive, just put the card in an anti-static bag and then put it in your freezer for half an hour. that will allow you to pop the heatsink off with no problem. be careful with the pushpins, though. it's easy to slip with the pliers.
--jacob
