- Jan 12, 2005
- 17,305
- 1,002
- 126
I have my 9370 up and running, quite the experience diving into water the first time.
I am in the process of overclocking and stability testing right now. My question is to those who are somewhat in the know with AMD / Vishera / 32nm, assuming good temps, what would you say the maximum safe voltage is for 24/7 use? What do you think the chip can handle for the occasional benchmark session where I push harder?
And lastly, can anyone suggest a good temp monitoring program for AM3+? Coretemp and AMD's own Overdrive just bounce around, often below ambient. Or will I likely be flying blind?
Thanks!
Thanks!
  I will win this argument...! :biggrin:
