The virus is called Security System 2009. I am not sure if I have that or more, but here are all the details.
So I come home and I see this virus on my computer. I realize I can't run any of my programs Not Norton(well norton runs but it will not run a full system scan for some reason) or Spy Sweeper. So I have two internal hard drives. One I run windows XP pro and the other Linux Unbuntu. So I log off of XP and into Linux. I hop online and research the virus. So I found a few sites and they all basically say the same thing.
Log in XP in Safe Mode and do one of two things.
Download malwarebyte run it and remove the virus/spyware or manual do it.
So I download malwarebytes anti-malware and install it, but it doesn't run. It installs but it doesn't run, at this point I notice my spy sweeper doesn't run either. So then I try to do it manually.
So I think there are 3 steps here.
1. Stop/Kill the process of the virus/spyware. So i go to task manager, however everysite says it will say system security.exe. I never see this so I just move past this step.
2. Is to search for and find the folders. So in this step the sites show the pathway.
Something like C:/Documents and Settings/application data/All Users/[Random Numbers]/[Random Numbers](something like that). So I found 2 folders that had random numbers for names. Actually 3 but I only deleted 2.
Now here I am not sure if I deleted something important. the two folders I deleted did have the Virus Icons in there but they also had other stuff but it said to delete the folders I think, so I did.
3. To disable start up so I went into msconfig and I noticed those two folder names with random numbers were being called at the start up so I unchecked them.
4. And last step was to delete the Virus/spyware in the Registery This part I thought would be simple but when I to the Registery following the path they gave on the websites I couldn't find the Virus it wasn't there so I skipped this part and restarted.
Now my PC starts up in normal mode I can Hope on the Internet but there are still issues/malware there. Maybe even a virus. I still can't run Spy sweeper or malwarebytes anti-malware.
I run Norton for a full system scan and it only scans like 5 thousands files(not the full system) and it keeps coming up with a packet 200 virus or something that can't be removed.
Also i notice some others don't work like I can't run World of Warcraft anymore.
So if someone can help I would truly appreciate it. Thanks guys for taking the time to read this long long email.
