Virus problems
UnoSigmaPi
919
I have a problem where i don't know how to get rid of some viruses. I run AVG everyday, and I have ran adware, and spy search and destory. Nothing can up on AVG so i figure everything was ok, but my computer has been running really slow lately. So I ran a symantac virus scan, and it turned up 39 viruses. I then ran AVG in safe mode and that didn't find anything... i'm at loss with what to do. Please help!!! I really do not want to reformate. Thanks!
Sureshot324
3,370
AVG is one of the worst antiviruses there is. Run trend micro's online scan (www.trendmicro.com) from safe mode. Go into msconfig (start>run> type msconfig> go to startup tab) and google everything you have there, uncheck everything you don't need. Google everything in your task manager. Run hijack this.
FlyingPenguin
1,793
AVG is fine. It does the job. I recommend it to most of my clients if they have broadband. It's not good on dialup because it uses a schedule for updates. I prefer it over Norton or McAfee - especially on older systems - because it uses little memory and CPU time. Norton has turned into a giant 120Mb code bloated monster.
Only really good AV app in my opinion is McAfee Enterprise, but that's pricey for a home user.
The free version of AntiVir also does a good job.
NO AV app will do anything about spyware which is probably what you have. Adaware and Spybot have been off most professional IT people's radar for at least a year. Spybot doesn't detect anything anymore and Adaware sold out to the enemy.
I do this for a living. Just running a spyware scanner from regular Windows mode DOES NOT WORK. You need to do your scans in safe mode and you need to check for other things that your spyware scanner will not usually check for (malicious BHOs, compromised HOSTS file, etc).
Please refer to my detailed spyware cleaning instructions here: http://theflyingpenguin.com/spyware-removal.shtml
Afterwards run a FULL virus scan in SAFE MODE.
There's also nothing that will protect you if you perform risky actions. Refer to the spyware tutorial here: http://soldcentralfl.com/flyingpenguin/spyware/spyware_help.html
For people who are prone to spyware infections I recommend installing either Microsoft Anti-Spyware or Webroot SpySweeper and leaving them running in the background. HOWEVER it's up to YOU to heed the warnings of these programs.
Hope this helps...
Sureshot324
3,370
AVG is easy to use, not a resource hog, doesn't cause a lot of problems, but it has the lowest detection rate of all the popular AVs. And isn't that the whole point, detect and stop viruses?
Don't believe me? Check out http://www.av-comparatives.org/
Personally I think if you're an experienced computer user, use firefox or opera, get all windows updates, then an antivirus is not even necessary anymore. I haven't used one for years and I never get viruses.
mechBgon
Oct 31, 1999
30,699
UnoSigmaPi, if you want to bring the full wrath of McAfee's latest engine and definitions down on your pet viruses on a one-shot basis, here's how: scan.txt, right-click this and save it. It's a self-contained utility, just follow the directions and run it in Safe Mode as part of your attack when you follow FlyingPenguin's game plan.
