Virus help!
RettaGuy
Banned
Mar 20, 2003
371
I have got the following help:
Probably because the "virus" changed the registry key for opening executable files. Check the value of the following reg key:
HKEY_CLASSES_ROOT\exefile\shell\open\command
Make sure that it has <"%1" %*> as the value to get everything back to normal.
BTW, copy REGEDIT.EXE to REGEDIT.COM first so you can change this :)
HTH,
AVChap
... take my advice, I don't use it anyway!
how do i do this line:
when i try to edit the key it says i cannot edit it?
bsobel
Moderator Emeritus<br>Elite Member
Dec 9, 2001
13,346
Please do not cross post (see my response in your other thread).
Bill
