Originally posted by: pontifex
it's been sitting at "extracting windowing system, please wait" for like the past hour.
any idea what i need to do or does it normally take this long?
I have no idea... but some installs (and sadly, especially sun installs) can take hours. Give it overnight before you panic and abort it.
The 'best' way is either to VM it (which you're doing) or do a legit dual boot... which is kinda a PITA with Solaris 10 anyway.
Originally posted by: Colt45
try again?
I installed opensolaris in a VM fine ( no longer than a windows install), so i assume solaris 10 should'nt be _that_ much different?
I downloaded solaris 10, and will try it later, and post back 🙂
whats the difference between opensolaris and solaris 10?
Originally posted by: JohnOfSheffield
You'll just have to set up your keyboard right and it'll work just fine, backspace and all. 😉 You can do that in the system settings in the graphical interface or by editing your profile by hand.
Seriously Solaris isn't really the best way to get an introduction into the Unix/Unixlike world but i guess you don't have much of an option.
Originally posted by: Fallen Kell
To setup your keyboard's delete:
stty erase ^H
The above should be fore backspace, either that or ^?, in anycase, just hit the key that you want to become the erase character if it is not already set that way. You can copy/paste and put it in your "~/.cshrc" file or "~/.bashrc", or "~/.profile" (it depends on what shell you chose to use, .cshrc is for csh, bashrc is for bash, and profile is for bourne or sh).
...it seems really slow...
Isn't there a free version of VMware or some other virtual pc software? I may try that instead.
