Virgin to case modding, need some help...
canadianpsycho
3,417
Can anyone drop me some websites with info/tutorials/pics on:
-Best methods to cutting holes for fans in a case
-Recommended paints/methods for painting a case
-Rounding ATA66/100 IDE cables?
Thanks!
canadianpsycho
3,417
thanks a ton for the links.
Been looking around a bit, was hoping somebody had already done the dirty work of weeding throught them all :)
Junior77
300
Newbie to modding myself. Just actually cut my first two holes (one intake and one blow hole) with a dremel. Just traced the grill, put masking tape around the circle (so you don't scratch or go beyond the perimeter), and starting cutting away.
I first started out on the first speed with the dremel, and didn't think it was going to happen. Got kind of nervous with all the sparks. But I threw it at the highest speed, and took about 10 minutes. Then I sanded them out with the sander bit (whatever it's called).
