Virgin Mobile HTC One V $49 at Radio Shack
Discussion in 'Hot Deals with Free Stuff/Contests' started by Jim, Dec 23, 2012.
  1. wiredspider
    wiredspider Diamond Member
    Jun 3, 2001
    5,239
    Yep
  2. Elfear
    Elfear Diamond Member
    May 30, 2004
    6,568
    75
    Any chance this can be activated on T-Mobile? I currently have an Exhibit II and it is so slow and unresponsive that I can hardly stand to use it.
  3. wirednuts
    wirednuts Diamond Member
    Jan 26, 2007
    7,121
    the exhibit II is a pos. it has nice specs but the phone doesnt work like it should. and the ambient light sensor is known to not work on those phones. very annoying.
    this htc one v is cdma, so it will not work on tmo.
  4. Elfear
    May 30, 2004
    6,568
    75
    I'll keep looking then. Thanks for the info.
  5. SunnyD
    SunnyD Belgian Waffler
    Jan 2, 2001
    32,566
    8
    Easy to get non-Verizon CDMA phones on PagePlus for Talk'n'Text only.
    Requires a "donor phone" to get working data though.
  6. SunRey
    SunRey Platinum Member
    Jun 8, 2003
    2,472
    Thank You!
  7. bamx2
    bamx2 Senior member
    Oct 25, 2004
    476
    Yes, a donor phone and full version of CDMA workshop for 3G data. More trouble than its worth unless you want to make it a hobby project . Another alternative is to look for a flashing service ($50?) which makes this phone much less of a deal .
    #32 bamx2, Dec 25, 2012
  8. RossMAN
    RossMAN Grand Nagus
    Feb 24, 2000
    78,238
    83
    Do you have any model suggestions for cheap donor phones on CL/eBay?
    I'm not sure what specific models I should be searching for, thanks.
  9. SunnyD
    Jan 2, 2001
    32,566
    8
    Afaik, any 3g capable phone that's not motorola. From what I know Moto phones have the necessary keys locked down in memory and are very difficult to find.
  10. 123werty
    123werty Junior Member
    Jan 22, 2013
    Where did you get 6% from ? :(
    I managed to find 5% from Upromise and then found 7% from TopCashback.com, does anyone know much about them?
