WT
I'm a first time case modder that wants to do the mods right, rather than just getting it done. I chose a Compucase 6919 tower in black with a silver lower insert. The optical drives I currently have are beige so I purchased Testors silver spray paint yesterday for the CD faceplates. This matched perfectly to the lower panel so I'm in good shape at this point. Now the tricky part ... I want to use vinyl dye on the drive trays themselves but haven't worked with vinyl dye before and have found little info online to guide me along. A local shop carries SEM spray-on dye, so my questions are:
(1) Can I just spray this stuff on with no sanding to the front of the tray or do I need some prep work ?
(2) Does it require additional coats or should I go VERY light and let that dry sufficiently, then add a second or third coat ?
(3) What kind of drying time am I looking at for each coat ? Since the dye itself ingrains into the plastic, I would guess it is substantially longer than simple paint. A big no-no would be closing the CDRom and finding your tacky CD tray sticking to the faceplate. OOPS !
Thanks in advance for any comments or suggestions you guys can offer. I need to take some pics of my project too. Building a nice box is easy, its the little extras and added effects that require the most time but offer the greatest satisfaction when they are done well.
