I bought some Vinyl spray paint at Menards and all it does is leave a coat of the color on the plastic I'm painting. It chips off real easy. Glad I tested it first since I want to dye my faceplates to match my case.
Does vinyl dye actually dye the plastic or is it just a coating too. I'm concerned that a coating would just wear out over time and maybe even cause issues with my CDRW if it flakes off.
Thoughts? Experiences?
Thanks,
Pigseye
Thanks,
Pigseye
