Viewsonic Fastest LCD Display
mzkhadir
ViewSonic has recently released a very exciting product, a nineteen inch LCD display with a 3ms response time. This is the fastest LCD panel currently available to consumers, and it is clearly aimed at gamers and movie watchers. Dubbed the VX924, the display is part of ViewSonic's X series which tries to comnbine performance with style. The word on the street is that Samsung will have a 4ms display available this year, but this may be the only 3ms."
http://www.xyzcomputing.com/index.php?option=content&task=view&id=457&Itemid=2
Any word on whether it's a 6-bit or 8-bit display? I didn't see any mention of it in the specifications.
http://www.viewsonic.com/products/desktopdisplays/lcddisplays/xseries/vx924/
LCD Panel Type 19" color TFT Active Matrix SXGA LCD
Display Area 14.8" horizontal x 11.9" vertical x 19.0" diagonal
Optimum Resolution 1280x1024
Contrast Ratio 550:1 (typ)
Viewing Angle 160° horizontal, 160° vertical @ contrast ratio > 5
Response Time 3ms gray-to-gray (avg.); 5ms white-black-white (typ)
Brightness 270 cd/m2 (typ)
Light Source Long life, 40,000 hrs. (typ)
Panel Surface Anti-glare
INPUT SIGNAL Video RGB analog (75 ohms, 0.7 Vp-p); DVI-D (TMDS, 100 ohms)
Sync H/V separated (TTL), composite, sync-on-green
Frequency Fh: 30~82kHz, Fv: 50~75Hz
COMPATIBILITY PC VGA up to 1280x1024 non-interlaced
Mac®* Power Mac" G3/G4/G5 1280x1024
CONNECTOR Analog/Digital 15-pin mini D-sub/DVI-D
Power 3-pin AC plug, (CEE22)
POWER Voltage AC 100-240V, 50-60Hz (auto switch)
Consumption 35W (typ)
CONTROLS Basic Power, 1, down, up, 2
OnView® Auto image adjust, brightness, contrast, input select (analog, digital), ViewMatch® color adjust (sRGB, 9300K, 6500K-default, 5400K, user color - RGB), information (resolution, H. frequency, V. frequency, pixel clock, model number, serial number), manual image adjust (H. size, H. position, V. position, fine tune, sharpness), setup menu, language (English, French, German, Italian, Spanish, Finnish, Japanese, Traditional Chinese, Simplified Chinese), resolution notice, OSD position, OSD timeout, OSD background, memory recall
OPERATING CONDITIONS Temperature 32-104°F (0-40°C)
Humidity 10-90% (non-condensing)
DIMENSIONS
(WxHxD) Physical 17.0" x 18.4" x 7.9" (with stand)
431mm x 468mm x 201mm (with stand)
17.0" x 14.6" x 2.6" (without stand)
431mm x 370mm x 66mm (without stand)
WEIGHT Net 14.8lbs (6.7kg) (with stand)
Gross 18.7lbs (8.5kg) (with stand)
REGULATIONS UL, cUL, FCC-B, CB, CE, ENERGY, NOM, NEMKO/GS (covers TUV/GS), NEMKO ERGO (covers TUV/ERGO, ISO13406-2 & MPR II), TCO'99, GOST-R + 20 original copies hygienic, SASO, PCBC, VCCI, BSMI, CCC, PSB, C-TICK, Argentina-S, PSE (power adapter), Green Mark
POWER MANAGEMENT Meets TCO'99 and ENERGY standards
PACKAGE CONTENTS LCD display, power cable, 15-pin VGA video cable, DVI cable, Quick Start Guide, ViewSonic Wizard CD
WARRANTY Three-year limited warranty on LCD, parts and labor
Originally posted by: Tiamat
too bad the resolution is terrible... need more 1600x1200 at least...
I'd like 1600x1200 as well, but this bad boy might finally spell the end of my CRT.
EDIT: On a side note, given the 5ms white-to-black-to-white time and the 3ms grey-to-grey time, I'm assuming this is some sort of FFD technology? That was supposed to come out on the Mitsubishis a LONG time ago, but never panned out.
You would want an LCD bigger than 19" if you want 1600x1200
Originally posted by: aswedc
Can anyone actually tell the difference?
Yes. To MOST people, an actual grey-to-grey response time of AT LEAST <9ms is required in order to not see ghosting.
I bet its really 6ms. Viewsonic do not manufacture LCD panels. I think they get their Panels from Philips/LG and they say its 3ms just to their testing specs which is usually false. Samsung in the other hand make their own LCD's panels and label their specs correctly.
I don't get it. To refresh the screen once every 9ms or less, the refresh rate would have to be 111hz. Aren't you supposed to run LCDs at 60hz? And if the screen refresh takes longer than the response time, how can there be ghosting?
It came out a while ago, and there are a lot of bad reviews due to it "sparkling" Supposedly how they have such low response is that the monitor shoots past what it needs to be at right away, but then takes more time to settle back down to what it is supposed to be.
Do a search in the video forum
