ViewSonic E90 19" Monitor for $235 hot or not?
Well, I bought a 17" Viewsonic a while back and have been pretty happy with it.
But this seems a bit high, as it does not appear to be a flat screen model. I'm still liking the Samsung 955DF, I think.....
I didnt read all the specs but if it isnt a flat screen, then Idont think its worth it because you can get a flat screen for about this price or even less .. if you care more about the amount of desktop space on your screen than the actual space that your monitor takes then get a 19inch but if space conservation is your priority get an LCD
my two cents , hope this helps ...
