Video Problem????
aznepic
I disable my video card, now when i turn on the computer there are no picture, how can i fix it?? do i need to buy a new video card. i don't know why i disable my video card, the computer load up normal but after the window xp logo show up, the screen are black. i think the computer work but how come i don't see icon on the screen?
Go into windows safe mode (or VGA mode) and do a system restore and go back to the point before you disabled your vid card. Or if you are able, enable the card in device manager while in safe mode.
Keys
Exactly right ... that should fix it! Any time you have issues similar to this, always try to boot into the safe mode, before you do anything else. If what keysplayer2003 says to try doesn't fix it, then check your BIOS settings. If you are seeing the WinXP logo, your card is probably fine ... it may just be a driver issue. You might want to try to unistall and reinstall your drivers if you can get into it in safe mode.
