I'll preface this by saying I'm a hardware novice.
AMD2600, 2.14GHz
Gigabyte GA7vaxp mobo
ATI 9700 vcard
512MB ram
I just moved my desktop back home from college for the summer. I moved it once prior without problem-- but this time, after about a half-hour of use, I noticed weird multi-colored spots on my monitor. To be short, I began thinking the problem was the monitor, ruled that out, thought it was the video card, resat that, and then discovered that my cpu temp had jumped to 63C. This at least 20C above average, and the case temp had not noticably changed. I unhooked the heatsink, re-applied thermal compound, and rehooked it, and the case dropped back down to 48C, still higher than normal. I have not noticed the spots again, but I've not done anything more taxing than surf the web or listen to music. I'm a bit scared to try running a game or do some intensive graphic work because I think the temp will shoot up again.
I've read a few pages of this cooling forum, and you people sound way more knowledgable than me (I know that's not saying much!) so I thought I would ask your advice.
It has been brought to my attention that the fan on the video card could be the problem, but it seems to be running fine and I blew it out recently with canned air.
Would switching to Artic Silver compound really make that much of a degree difference? Additionally, the hsf I am using is Thermaltake's Orb 3. Should I switch to a higher end fan, or one that's lighter? It seems to be quite heavy, and I will be moving my case again in three months.
Thanks,
Lisa
AMD2600, 2.14GHz
ATI 9700 vcard
512MB ram
Thanks,
Lisa
