Video-Crazy hissing sound from 09 Acura MDX, scary, any thoughts?
Status
Not open for further replies.
theanimala
330
Happened tonight to my MDX, idling for a few minutes when it started. Turned off the car then drove it home. Left it running in the driveway for a few minutes when it happened again? It's dark so it's hard to see but there was a bit of smoke coming out from the head lights and grill after doing this. Also had a weird slight burning smell. Thoughts?
https://www.youtube.com/watch?v=mpRBj8S0p_E
theanimala
330
you didn't look under the hood?
Yes, I did. In fact the video was of the car with the hood open, unfortunately it was too dark to see anything. The MDX engine area is very small, but from what I could tell it seemed to be coming from more of the front / bottom section of the engine area, meaning it could be more the radiator (area). Wondering if an independent can take care of this or if I need to go to the dealer...
PottedMeat
12,363
475
hmm. that is really loud. and intermittent. maybe the tips of one of the cooling fans is hitting the radiator fins or the fan assembly is loose.
LTC8K6
28,520
1,576
Sounds like something releasing excess pressure.
Air Conditioning system?
Probably a stuck relay in the A/C compressor?
LTC8K6
28,520
1,576
Supposedly you can pull that relay out and stop it from happening.
thomsbrain
18,148
The AC compressor on the Honda J-series motors is one of the few things that will eventually wear out. I got 125,000 miles on my first. Have 130,000 on my current one so I'm just waiting for it to go.
Status
