Hey-
So back in 2002 I built this rig (with LOTS of help from the AnandTech Forums), and haven't done much since then. The basics go like this:
AMD Athlon XP 2100+ (1730MHz)
Chaintech Apogee 7VJL mobo
512 MB Corsair PC2700 DDR
Gainward 650XP Nvidia Geforce 4 TI4200
Audigy Sound Blaster MP3+
2 Maxtor drives totalling 280GB
Here's the issue: besides that fact that it's old in general and I can't really do much of anything anymore, recently I had a problem where while trying to watch a DVD, the whole computer froze and then just restarted. Now, when it restarted, everything on the screen was kind of garbled - from the BIOS startup right through Windows. I could see everything, but it's like there are these blocks that run vertically across the screen and slightly distort everything. I had greater issues including an inability to get into windows and some other problems, which, once I disabled my video card, went away (sort 0f).
So, I'm running without a video card, though the screen still has these yellow and blue columns running across it (that get bigger at lower resolutions and smaller at higher; and it shows up on an alternate monitor as well). After reinstalling DirectX and video drivers all to no avail, I've pretty much resigned myself to a video card that's finally bit it.
Two questions:
1) Has anyone had a problem similar to this before? I'm pretty much just assuming it's the video card, but I'd hate to get a new one and find out I have the same problem
2) Ideas for the best way to upgrade? Obviously since I'm pursuing this route, buying/building a whole new system isn't really in the cards financially. The obvious (and cheapest) start is to get up to 1GB RAM (it is LONG overdue after all). Looking at this article, I had started looking at the Radeon X1900 XT. So really, the question is everything else. Are my mobo and CPU just holding me back at this point? If I change out my mobo, will I be able to find something new that will still fit a majority of the parts I have now? What type of configurations would you try?
Thanks in advance for any help!
Two questions:
