video card overheat problem please help
guskline
5,338
476
Clean your AIO radiator. Just from your picture, I'm surprised that it isn't overheating. Second, I agree with blackened23 about the card you have mounted near the fans of your GPU. TAKE it out to give the cooling fans a chance. Third I would check the fins of your gpu to see if they are clogged with dust. You need to buy some compressed air and clean out that case before you measure the heat.
Mtt
64
Should have a serial number sticker on the card.
Were did you buy the card from?
I bought it from NCIX.
I have already done that(cleaning and remove the card below). The video card is brand new so no dust on it).
Kenmitch
8,505
2,249
Never bought from NCIX. Looking at their return policy it doesn't look like you'll have any issues with the rma to me....Unless there is physical damage to the card.
Mtt
64
wait,,i contacted ASUS for the RMA should i contact NCIX instead?
blackened23
8,548
Never, ever, go through a manufacturer for RMA when you're in a 30 day return window. I can't remember what NCIX return policy is, but if you can do that, do it. If you RMA to manufacturer you will be at their mercy for weeks. DONT DO THIS. I know people will complain about asus and while i've never had problems, this applies to all AIB manufacturers. Do. NOT. RMA to manufacturer if you're in a 30 day return period! Get a refund instead to reset your 30 day window. Increase your customer purchasing rights. RMA'ing to manufacturer lowers your rights as a customer, and you may wait weeks and get a refurbed card in return. DO NOT DO THIS.
Pretty simple choice. Refund = more customer rights, reset your 30 day purchase window. RMA to asus or whoever else = you're at their mercy, best of luck. Decreased customer rights.
The point of sale will always, without exception, regardless of brand, be less hassle than RMAing to mfgr. Even EVGA who is considered by many to be the best CS/RMA policy of anyone - I still would not RMA to them in a 30 day window. Because who knows how fast their T/A will be, whether they charge you for shipping, and whether you get a refurbed card in return. Now EVGA is great. But they're not preferable to refund to point of sale, not by a long shot. There are too many variables which are annoying to deal with, such as shipping costs, turnaround time, etc etc etc.
By the way, even if you're RMA'ing the card - do not ignore the advice of either getting a non POS chassis or improving your air flow significantly. That's going to increase your temps by 10-15C or more, because frankly, your chassis and air flow sucks. Now the card could well be bad. But the chassis isn't helping matters. And don't put a card directly underneath it. You don't do that with aftermarket cooled open air cards.
So return it to NCIX if you're able if you can avoid restocking fees, get a refund. Buy a new card, reset your 30 day window. Buy a new GPU of your choice, it can be the same card or you can find whatever GPU you want. Then. I would suggest buying a case that doesn't suck. Or at the least, a ton of fans. It's up to you. But like I said, the card may be bad but the chassis certainly isn't doing you any favors either. Especially with a card directly under your open air cooled GPU. Just my advice, definitely look into it. I think your case is beyond saving because the positioning of your frontal HD cages is truly awful for air flow. The alternative of course is to get a reference blower type cooler, which doesn't exhaust hot air in your case. But, I think the chassis and air flow would be the better option for a 290X custom GPU rather than a reference 290X.
Mtt
64
thanks, i will return the card then. My fans are on their way. I will see how they perform inside my case then decide if I need to change the case. Regarding the position of HDD and in take fans, I found that most of Corsair's cases are design that way(HDD blocking intake airflow). I guess they want to cool the HDD but that doesnt need much cooling I believe. I dont like many designs of my case(its corsair 550). Its not good and its expensive.
wand3r3r
3,180
Well said! :thumbsup:
blackened23 hit the nail on the head.
Opening the case and fans at 100% should have dropped those temps significantly. Get the case fans, they will make a nice difference, but if opening the case didn't help then there's a problem.
ASSus (USA) has terrible RMA service, you are lucky you mentioned it here. They would have either sent you a "refurb" that probably doesn't work, or the same card back. I've had horrible experience with them and can't recommend avoiding them enough, and from the multiple complaints I can see others saying the same.
If you can return it, grab a MSI Gaming, XFX DD, PCS+, or alternatively a TRI-X if it will fit in your case (long). If they will only exchange it then go for that.
Mtt
64
I did consider all those cards.
PCS+ and XFX DD have only 2 years warranty whereas the others have 3.
MSI is $30 more expensive and TRI-X is $100 more.
Im not sure if the extra is worth it.
The gigabyte is at the same price.
wand3r3r
3,180
I believe XFX has a 3 year warranty with registration. According to this it's lifetime but I thought they quit lifetime earlier. I'm not sure. Verify it before you buy since I'm really not sure.
Nobody likes to RMA their video card because it usually means going without use of the computer, which is why construction is so important. According to XFX marketing representatives, any new R-Series graphics cards with Double Dissipation receive a lifetime warranty if the owner registers their card with XFX within 30 days of purchase. Should the XFX Radeon R9 290 DD Black Edition graphics card fail during the warranty period, technical support is available by registering your product at xfxsupport.com.
http://benchmarkreviews.com/11725/xfx-radeon-r9-290-double-dissipation-review/15/
escrow4
3,339
122
You are running very hot and thirsty AMD parts in a case that is absolutely stuffed and has little room to breathe. Return the card for a third party one with a good cooler and get something like a HAF X.
Mtt
64
I took the card to the store. I asked for an exchange and got a new card.
I explained the issue to a repair personnel and he actually ran Furmark on the card and got the exact same result as I did. He said the card is fine. Its just that Furmark is too demanding. He can give me a new card if I want but I cant use the same reason to replace again.
I got home and did some testing. Both are with side pannel off in the same environment.
Old card running Furmark
New card running Furmark
I would say there is definitely something wrong with the old card.
I hope they are not gonna just sell the old card to another customer.
The old card also makes a noticeable buzzing sound when mining. I tested with the new card and the buzzing sound is gone entirely.
Thanks everyone for the help. I am glad that I didnt send the card to ASUS.
