imported_microbe
So my old EVGA 8800GT OC (and then some) finally bit the dust after over three years of warming the entire room. I simply need a balanced replacment as this old system will become my sons and I will be building a new custom X58 based system for myself as soon as I can.
Here are the specs: Gateway FX 7024
Core 2 Quad Q6600 (2.40 GHz)
Intel G33 Chipset
3072 MB DDR2, 667 MHz, (PC2-5300) dual channel memory
500 GB, 7200 RPM, SATA II hard drive
400 watt Power Supply
GEM 19" CRT (playing @ 1280*960 rez)
Vista Home Premium 32bit
Overclocking is a no go on this mobo and so is upgrading to Windows 7. Unless! Is this systems CD key locked to a 32bit copy of Vista, or are Vista CD keys interchangable with 64bit copies as well??? If not then 32bit it stays. I'm not looking to spend any extra money on upgrades other then getting it back up and running again.
So being stuck at that rez, with a stock q6600, and a 32bit OS holding memory at 3 gigs, I'm looking for a good non-CPU-bottlenecking video card. From what I have read a Video card with 1gig vram is overkill for that rez, so I'm looking at either a 5750 512mb card, or on newegg I see that PowerColor makes a 5770 512mb card. http://www.newegg.com/Product/Produc...82E16814131328 Are these two cards the sweet spot for this system?
I googled around a bit about the PowerColor card and have read a few people are have issues getting the new Catalyst 10.2 drivers to take as this is a nonreference board (512mb vram 5770). Anyone know anything on that?
Intel G33 Chipset
