video card heatsink question. please help!
cyberserf
58
Hi,
I removed video card heatsink from my Visiontek Geforce3 ti200. I needed to do this so I can use my dremel to remove some of the portions of the heatsink so my video waterblock can fit. My question is what type of glue or substance should I use to stick the heatsink back onto the memory chips. The substance that was there seems pretty hard and I dont know what it is or what to use. any ideas? links to purchase?
Thanks to all who respond.!!
cyberserf
58
thanks Blain,
Anything that I can get from the local HomeDepot that will work as good? need it now. checked Millesec.com but they dont seem to have the thermal stuff in stock. :frown: any other places on web that carries this material?
Thanks!!
cyber
