Video card for entry level HTCP - smooth 4K video/movies playback
Psyside
140
Ok, new problem now. MPHC is totally smooth, but Chrome 4K videos are absolutely the same even if i forced HW acceleration, tried flash and HTML5 same....
What can it be done to fix this? :(
NTMBK
10,297
5,289
Chrome is a mess for hardware acceleration. Try IE11, it usually seems to do a better job.
Psyside
140
It does MILES better job, but i just prefer to use Chrome, no one found a way to fix Chrome/4K? :(
Psyside
140
I got it working, but i found out that only the 32 bit version support madVR, problem being, i cant get the 32 version to work no matter what due to some strange bug, i install the X86 version, but it does install the 64 bit instead? deleted the downloads, and tried from scratch, used revo uninstaller, and tried to even reboot after, did this 3 times, nothing helps.
http://i.imgur.com/khXtz13.png
Always 64 bit installed at the end, even i use 32 bit installer?
ViRGE
Elite Member, Moderator Emeritus
167
The 64-bit label is the operating system, not the version of MPC-HC. If you installed the 32-bit version of MPC-HC, then that is what you have.
ShintaiDK
20,378
145
Remember codecs are 32 or 64bit. And you need 32 or 64bit for 32 or 64bit players.
So if you take WMP that you got 2 editions of in a 64bit Windows, they dont use the same codecs of the 32 and 64bit versions. That may be your issue. 64bit today still got poor support.
UaVaj
1,546
great info on htpc 4k playback.
however this should be moved to the htpc subforum.
