The fan stock fan on my GF4 is 12 volts, and every aftermarket chipset/vga cooler I've seen is 12 volts.Originally posted by: Eug
What is the voltage used for fans attached to video cards? I have a Radeon 9100.
I have my 2-pin connector on a 3-pin adapter, running to a 7volted line directly off of my PSU. There was no change in fan speed from my video card header to my 12 volt PSU connector (before I dropped the voltage to 7, that isThe reason I ask is if it's possible to undervolt it using a connection to the PSU instead.
I suppose, but I would not have any idea which one to buy.Originally posted by: OulOat
Or you can use an resistor and lower the voltage some more.
OK Will look into the resistor. I might have to do trial an error. Grab a 5 Ohm, 20 Ohm, and 10 Ohm. Anything else I need to know?Originally posted by: OulOat
Find out what current your fan needs and use the equation Voltage = Current * Resistance to find out which resistor you should get. For example, say your fan requires .1 Amps of current and you want the resistor to dispel 1 V, you would need a 10 Ohm resistor. Then just insert the resistor in either one of the wires and you would lower the voltage your fan gets by 1 V. Simple mod.
Or if you feel that is too complicated, you can just get a Crystal Orb (the only ThermalTake product I like), lap the nickel off the bottom (3 hours of work), and use it as your fan. It will cool very well at 7 Vs and is pretty quiet.
Originally posted by: Naythn
Are you using a swiftech heatsink to passively cool the northbridge? :Q
