Video Card Fan died need help with a replacement
golfgod04
I have a VGA LEADTEK PX7300GT TDH 256MB video card and the fan died on it. I cant seem to find a replacement that has the same hole pattern that would fit the video card. Anyone know how I could find out what fan would fit/work properly or know what fan would? Thanks in advance for the help.
I tried emailing them cause when i called them for service the wait time was over an hour and I havent heard back from them..guess i'll try again on monday..thank you for the advice
If you are tired of waiting and want something much better than stock, I would recommend the Zalman VF-700 or VF-900. I've had both and they are really good coolers.
I can use that Zalman fan, however, it is so big, it would cover up the next slot on my mobo. Anyone else have any recommendations?
I finally heard from Leadtek. They wont ship me the fan , they said i have to send it back for RMA and it would take them 6 to 16 weeks before I get the video card back. That's ridiculous
The VF900 is about as low profile as you can get in aftermarket coolers.
Do you really need that slot by your video card?
Too bad I didn't see your post a few days earlier. I had the same card as yours and was going to put a Zalman VF700 on it. I had heat sinks on the memory and pulled a memory chip off the board while removing the heat sinks. I threw the original fan away with the board.
