Video Card Doesn't Fit...Problems Restarting...
dpk777
I can see that my Xentor 32 TNT2 Ultra doesn't quite fit all the way into the PCI slot.
I've tried multiple times to adjust the card, but it still won't fit correctly. All the other cards fit in fine.
I can still turn on my computer, play games, etc...
Sometimes when I restart my computer it doesn't restart and I have to try it again until it does...I don't know if this is due to the video card.
I had the same symtoms when my power supply was starting to fail. You turn it on and it doesn't post, then you restart a few times and everything works just fine right? Well, when I let those symtoms go for a while, my PS went poof. Also if your vid card is seated funny it may cause an electrical fault or something, but I'd think it would burn out the slot or the card if it was shorting...
uhm....the Xentor is an AGP card. Look for a shorter brownish slot and try installing in that and hope your card still works.
~Ladi
<< uhm....the Xentor is an AGP card. Look for a shorter brownish slot and try installing in that and hope your card still works.
~Ladi
ROTFLMAO!! 😀😀😀
