Video capture on 2nd adapter will this work??? Need Help Please
ffwd
52
I have a dell 4300 with using a ATI Rage Fury Pro 32meg AGP card as my main video adapter. I want to capture video from my sharp camcorder using s-video and stereo sound. I have at my disposal an old ATI All-In-Wonder Pro 8meg pci card. If I install this old adapter using an availible pci slot. Is there a way to get it to capture video? I have tried but have had no luck. There are few problems. My main adapter has video in but only composite.(No audio in but I can use line in.) My camcorder has has composite video out but the jack is messed up and it is putting out really bad video. On the bright side I have this machine setup as a dual boot Wink2k and Win98se. I have tried many variations of drivers and capture drivers from ATI with no luck. Is there a way to get my system to use the older All-In-Wonder as my primary display adapter? If I temporarily disable the the AGP adapter, will the system then use the PCI adapter as it's primary display? Can anyone give me suggestions or ideas to try?
Thanks in advance........
RobsTV
2,520
You will need to go into the PC's bios and switch initial display first
from AGP to PCI, then the other card can be installed as primary.
To use extra features on a video card, it must be the primary card.
ffwd
52
Thanks for the answer, it's kinda what I thought. So if I go into the bois and change this, will it matter what pci slot I have the AIW in? Should it be the first slot after the AGP slot?
