- Jul 5, 2005
- 10,084
- 4
- 76
I have a 3650 HD AIW installed in my lil bros comp a couple years ago. But the past 3 weeks, I noticed yellow pixelated artifacts popping in certain shades of grey and pink.
I loaded CPU-Z to check the temps and it's showing around 51-60 idle and 84 C on load with furmark !!!! (no artifacts on furmark tho). But then, as i loaded a demo for whiteout from AMD's website. String like artifacts are going out of control. From all the reviews i read, idle temps should be at least 35 C ~
There were no dusts around, I made sure of that. I added a 120 MM fan on the side of the case (HP case do mind ya
) to aid some cooling. Still, there was a no go. It's almost 2 years since the purchase, warranty...doesn't seem likely.
What are my options?
- should i try to attempt to re apply thermal paste? (save $$$)
- get a similar card or better? (very little gaming btw, just aiming, facebooking, wonderking >_> )
- use 4650 HD on hand and get a better for my other comp >
I got their comp from a walmart 2 years ago black friday.
1 pci-e 16x
sempron x2 core
450 W PSU
2 gigs for DDR 2 ram.
update:
Well it comes to the point that the 3650 is not getting any better...I'll replace it with 4650 HD xfx from my work comp. The question is, will a gts 250 will have a better performance boosts in terms in gaming @ 1440x900 over the 4650 ?
update: 6/2
I added the 4650, no artifacts showing up on the whiteout demo (from ati's website) thank god lol. BUT yellow pixelation/lines/waves still pops up on shades of white/highlights now. The 4650 HD that i get from my other machine is still running great, I dunno why yellow pixels still popping out with different card.
*Since it only draws power from the mobo...is it the motherboard that is failing? (so far nothing has crashed since 2 years).
*Was it the power supply not powering enough juice to the card? It's a 400 W psu that I grabbed from newegg 2 yrs ago.
*Should I do a clean reformat and see if the yellow pixelations go away ?
update: 6/3
* I swapped with a different power supply, still yellow pixelations still pop up.
* I grabbed a different monitor, and plugged to it's vga port. NO pixelations. And I wonder what the hell is going on. Probably I guess the VGA port in the Westing house HDTV32" is causing the problem.
* I grabbed a DVI to HDMI cord for the HDTV LCD, then of course made it go hdmi and there were no pixelations. Problem solved? so far it's not showing up.
So the question is that, could VGA ports can go bad on a monitor/hdtv over time? It's almost 3 years + old now. And I wonder after all the time using it heat/cold can cause some wear n tear on the circuitry? Anyways, I'm running the 4650 HD on HDMI and so far it's going well.
TLDR:
* thinking 3650 HD is dying slowly
* Pixel artifacts pops out on red/pink/gray shades and
* 3d application shows artifacts
* Made sure drivers are up to date, temps were fine and no dust bunnies.
* Changed vid card to 4650, slight improvemen, no artifacts on 3d applications. But yellow pixelations still occurs.
* Changed PSU, no change with the pixelation problem
* Changed Monitor from HDTV32" to LCD 19"W hp, pixelation is gone (using dvi to vga cord for both monitors)
* Thought it could be the vga port problem in the HDTV32"
* Used a DVI to HDMI cord from card to HDTV. yellow pixels is gone
*could it be that the VGA port in the HDTV gone bad?
1 pci-e 16x
sempron x2 core
450 W PSU
update:
update: 6/2
update: 6/3
TLDR:
