6600GT bit the dust. I basically started out today looking at video cards and ram, since I need both. Current specs before I go further..
A64 3000+ winchester
VNF4 Socket 939 motherboard
2x512mb PC3200 value ram
6600GT (dead)
400W smartpower PSU
2 hard drives, dvd burner, floppy
I started looking at video cards. I liked what I read about the 8800GTS 320, so that was the starting point. Then I figured I need more ram, so toss on 2x1GB PC3200 for about $150. Then why have that much of a video card and not do anything with the CPU, so toss on a A64 4000+ for $76 and I quickly ended up with an $80 vid card death turning into a $600 upgrade. Not good.
So give me some direction here. I don't really play too many games, although I like to check things out here and there. For example I might try rainbow six vegas. I also do not have a monitor worth anything, and I'm not sure if/when I'll ever replace the 17" I have now. So, whatever I do play will be low resolution for the time being, and I suspect a much cheaper card would work fine. However, if I'm going to spend $200+, might was well get the 8800GTS?
Honestly I'd rather keep this as cheap as possible, so maybe a $150-$200 video card that would work really well at low resolution would work, and if you see something drastically wrong with either the CPU or RAM yell at me for that too.
Thanks.
6600GT (dead)
400W smartpower PSU
