Vid Card Advice.
Kard
231
I need a second vid card for my system. Im planning on getting another LCD ( a tad smaller then this 1901). I was wondering what was the cheapest PCI Nvidia card with DVI out?
Thanks much.
Kard
P.S. Do drivers of 2 different manufacturers get along together?
MrBond
9,911
What are you running now? I have the TI4200 version of this card:
http://www.newegg.com/app/ViewProductDesc.asp?description=14-127-077&catalog=48&manufactory=BROWSE&depa=1
And it came with a DVI-VGA adapter so you can run two monitors off of one card. It looks like that retail package has the same adapter. It's a great video card, you'd just have to ditch your current video card.
It would require one of your monitors be analog though, so if your LCD's are both digital, that may not be a great choice.
If you want a second video card, there's this FX5200 here:
http://www.newegg.com/app/ViewProductDesc.asp?description=14-128-163&catalog=48&depa=1
The only other DVI/VGA card newegg sells is a GF4MX, which you probably don't want.
